Has anyone figured out how to install 2012 without having it download the content over and over again?
2012 deploy issues
The key is to edit the Master.RAC.xml file. Just strip out anything you don't want installed locally. A fully stripped version is attached, just replace txt with xml.
This info comes from a Bret Thomson post over here.
Some good info on related topics at Revit Clinic.
GordonAttached Files
Thanks. Do you know if I can install on a machine without any internet connection?Scott D. Brown, AIA | Senior Project Manager | Beck Group
Haven't tested that. My guess is that it still tries to download and install the local help stuff, so the install is going to "fail" at some level. Don't know if it will continue silently and just log the issue, or drop to interactive mode, or fail totally and roll everything back. Hopefully the first.
Gordon
Has anyone deleted the other two flavors of content.xml from their RAC deployment? I don't understand why they need to be there. Also at the same level in the folder structure is a folder called 'en' that holds a ton of .cab and .xml files that seem like they are just extra baggage if you don't want your deployment to install content in the first place. I plan on deleting the files and running a clean install to see what happens if no one has done so yet.
You could try the Revit 2012 Deployment Utility
http://usa.autodesk.com/adsk/servlet...P=OTC-RSSSUP01Sander Obdeijn
Support Engineer
ITANNEX [Autodesk Gold Partner]
Personal Mailadres:
[email protected]
General Support Mailadres:
[email protected]
Originally posted by sander.obdeijn View PostYou could try the Revit 2012 Deployment Utility
http://revitclinic.typepad.com/my_we...t-utility.html
No response to my comments yet on that post
I went ahead and started over with a deployment recreation deleting the enu folder and the two content.xml folders for the other flavors of Revit. Seemed to work just fine and my install took all of nine minutes.:thumbsup:
This thread:http://www.revitforum.org/showthread...ollowing-Blogs and several others here and over...April 27, 2011, 03:19 AM
I tried leaving Revit 2012 to install overnight as it seemed to be stuck on '5 of 17 remaining'.
This morning I find that my C: drive is...April 8, 2011, 07:31 AM -
I was just trying to install the Building Design Suite Premium 2012 from my usb key, but I get error messages. See attached pictures. I also tried to...
Channel: Hardware and Infrastructure
June 1, 2012, 04:31 PM -
I tried to install RAC2012 but it took forever and I uninstalled it.
I tried 2-3 times but with problems...
It works only once... If I close...April 19, 2011, 09:09 AM -
I'm having a problem re-installing Revit 2012. I recent replaced my over flowing SSD and as such had to do a complete re-install, including other autodesk...August 10, 2011, 02:19 AM
