Hi, little confused here and need some adwise.. (sry about my Norwegian/ Eng)
I know the system requirements for 2011 Revit Arch., but reading around on the net
I`m getting a little confused about whats working and whats not..
Problem: I can quickly open and MOVE/LOOK around i revit, but clicking home/new wall.. it crashes.. with this text at the end of the journal:
Jrn.Directive "JournalDataChainOption" _
, "Walls", 1
' 0:< <<Begin build CT>>
'Edit mode: IDR_COMMON
'Command: ID_OBJECTS_WALL
'Category: 0
'Bar list:
' Dialog_Revit_DynamicLabelDBar
' Dialog_Revit_FamilyBar
' Dialog_Essentials_CurveCreate
' Dialog_Essentials_LevelSelectionWString
' Dialog_HostObj_KeyRefDlg
' Dialog_Essentials_WallProp
'CT [Modify | Place Wall]:
' {1} spacer_shr
' {20} DPPanel
'Cache:
'<<End build CT>>
' 0:< Delta VM: Avail -3 -> 8387028 MB, Used +14 -> 544 MB, Peak +13 -> 544 MB; RAM: Avail -15 -> 1864 MB, Used +16 -> 531 MB, Peak +8 -> 531 MB
' 0:< Exception occurred
'C 09-May-2011 17:57:10.666; 0:< ExceptionCode=0xc0000090 ExceptionFlags=0x00000000 ExceptionAddress=000007FEE7E1E1EA
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 1864 / 4093 531=InUse 531=Peak
' 0:< VM Statistics: 8387028 / 8388607 544=InUse 544=Peak
' 0:< 0000000041D17728 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17828 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17928 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17A28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17B28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17C28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17D28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< 0000000041D17E28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 0:< TaskDialog "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects.Would you like to save a recovery file?."
'Id : TaskDialog_Unrecoverable_Error
'Command Links:
'1001 : Save recovery file under new name and exit
'1002 : Exit without save
'DefaultButton : 1001
' 0:< Delta VM: Avail -19 -> 8387010 MB, Used +3 -> 548 MB, Peak +3 -> 548 MB; RAM: Avail -4 -> 1860 MB, Used +3 -> 534 MB, Peak +3 -> 534 MB
' 0:< DBG_WARN: TaskDialog Exception::
'External component has thrown an exception.: line 96 of .\TaskDialog\AdWindowsTaskDialog.cpp.
'H 09-May-2011 17:57:10.838; 0:<
Jrn.Data "TaskDialogResult" _
, "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects.Would you like to save a recovery file?.", _
"<unknown>", "-1"
' 0:< DBG_WARN: Invalid TaskDialog response. For more details, see the wiki article: http://wiki/display/aeceng/Revit+Tas...alogs-DBGWARN: line 320 of .\Dialog\ATaskDialog.cpp.
' 0:< DBG_WARN: TaskDialog_Recoverable_Error: line 378 of .\Document\DocHook.cpp.
'C 09-May-2011 17:57:10.838; 0:< program terminated
Autodesk says:
The Software Requirements for 64-Bit Autodesk Revit 2011 Architecture
Operation Systems for Revit 2011:
- Microsoft Windows Vista 64-bit
- Intel Pentium 4 or AMD Athlon dual-core processor with 3.0 GHz or higher with SSE2 technology or Quad Core Intel Xeon with 3.20 GHz, 8M L3, 6.4GT/s Turbo or equivalent AMD processor (recommended)
- Minimum of 3 GB RAM (8 GB of RAM is optimal)
- Minimum of 5 GB free hard disk space to install Revit
- Display with a minimum of 1,280 x 1,024 pixels with true color
- Graphic Device and adapter with 24-bit color, minimum of 256 MB RAM, DirectX 9 with Shader Model 3 for advanced graphics
For system info on my 2 year old pc I got:
Dell Precision M6300 -
Processor Intel(R) Core(TM)2 Duo CPU T9500 @ 2.60GHz
Memory (RAM) 4,00 GB
Graphic card NVIDIA Quadro FX 3600M, Dedicated 512 mb
Gamegraphic 2303mb total
Shared system memory 1791 mb
Primer harddrive 81GB free memory
Screen 1920x1200
Win Vista Ultimate 64
DX 9
Question:
Where does it go wrong? Is it cos I need 3.0 GHz processor?
Is there any way around, let`s say I can dedicate more memory or RAM to program?
Thanks in advance for comments and help here!
All the best from cadtilt
, "Walls", 1
'Category: 0
'Bar list:
' {1} spacer_shr
' {20} DPPanel
'Cache:
'<<End build CT>>
'Command Links:
"<unknown>", "-1"
Autodesk says:
Screen 1920x1200
DX 9
Question:
