Well, about my question, i think i understood from the help menu that the values of Area Type are a hard coded set of rules. I thought that were just simple text values. Now it seems if I want to specify an "area type" that is defined in the national standard and witch i want it to show in my language in the area tag (like a translated Gross Building Area) i have to do a text parameter.
And about the rules i think if the rules fit in one of the predefined rules from the Area Type parameter i can use the automatic settings, and if not, i will use sketch mode.
Ah, and the rules are here:
Area Type parameter
A related observation too.
The area is calculated by using the perimeter at the Computation Height parameter. In revit 2011 this setting was by default 4' or 1200mm above the level. It was a type parameter of the level system family. Now in 2012 is an instance parameter and is by default set to zero. So don`t forget to adjust in sections by selecting levels) all the instance Height Computation parameters if you think the zero value is not an appropriate value. In the wiki help for 2012 they have the explanation that is the same as 2011. I think they forgot to update.Last edited by gaby424; May 8, 2011, 11:42 AM.
Area Type parameter
I`m working at an Area Tag Annotation family.
You can use the OOTB label Area Type.
In the project you can alter this label by selecting the area "X" thing and at the instance property at Other category you have this parameter. It seems it only can have some predefined values that are not useful for me. Is there a way to insert more values here. Or I should make a Shared text parameter in the family to replace the OOTB Area Type.Tags: None
I have structural slab. I want to tag its area.
Among the parameters for Structural Foundation there is not parameter for area. So, I have to create...April 28, 2014, 06:08 PM -
I use my own area tag for my area plans... Area name, area, perimeter... and I added a shared parameter "calc_area" (type area) which is very...
Channel: Architecture - Family Creation
January 11, 2013, 05:36 AM -
I readily admit that I might just be understanding it wrong.. but BOMA rentable area has names such as Occupant Area, Floor Service Area and Base Building...October 28, 2015, 05:19 AM
Continuing with "Calculate..." series this time sharing a plugin for rentable area calculation.
Calculate Rentable Area
Channel: Third party Add-Ins, API and R&D
January 29, 2012, 11:30 PM -
I'm trying to create an Area tag that will read the Area value, divide by a particular Occupant Load, and then display the number of occupants for that...June 2, 2020, 06:11 PM
