it's nice that 2012 now has a way to turn off dimension leaders but is there a way to have off be the default and not have to change each and every dimension to Always Off instead of By Element?
Segment Dimension Leader Visibility?
Damn...:banghead: thought that new selection box was a default, but no!!
Why is off by default so hard to impliment.
I think we need a poll.
Dimension Leaders
Preference Off by Default or On By Default.
I am willing to put money on the OFF's
Surely this is just a ini. tweak to turn it off.Last edited by mark b; May 7, 2011, 02:09 AM.Mark Balsom
Originally posted by mark b View PostSurely this is just a ini. tweak to turn it off.Luke Johnson | Autodesk Expert Elite Member
Author of What Revit Wants
Jeff I am sure if you took a poll you would find "off by default" would be prefered option.
Personally the distance I move 95% of my dimension do not warrant a leader and tend to make dimension strings untidy.
My opinion, anybody else....?Attached FilesMark Balsom
Originally posted by mark b View PostJeff I am sure if you took a poll you would find "off by default" would be prefered option.
My opinion, anybody else....?I'm retired, if you don't like it, go around!
That's strange. Since you deal with details and very small dimensions. Don't you ever need to take the text string out of the dimension when it doesn't fit in the available space? , not even in "that other program"?Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Alfredo Medina View PostThat's strange. Since you deal with details and very small dimensions. Don't you ever need to take the text string out of the dimension when it doesn't fit in the available space? , not even in "that other program"?Attached FilesI'm retired, if you don't like it, go around!
This one has annoyed me for years.
Does anyone know how to have dimension text leader turned OFF by default.
Thanks MarkJanuary 15, 2011, 09:15 AM -
OK, these are my last two dumb questions,(not), I am a lying sack of s__t. But here goes two things I can't figure out that are bothering me.
...October 12, 2012, 07:53 PM -
Is it possible to be able to have a noticable space between a dimension and the leader when you pull the text away from the string?February 2, 2012, 05:25 PM
Does anyone know how to set the default dimension style in a project. Sadly It seems to default to the latest style created, which is only used in one...September 15, 2016, 10:03 PM
temporary dimension (dimension snap) remains large and off screen when zooming in.
When I zoom into an wall to enable the splitting command...October 27, 2011, 08:28 AM
