This is my first project with Revit. I begun designing the internal walls and doors within a single level, and then tried to copy to the other levels (because they are identical) I did this by selecting the elements, placing on the clipboard and then paste with "align to selected levels". This worked but I have some problems. 1) If a wall is too small to select because a door takes all the place, if I select the door it can not be copied because there is no wall to be placed in. 2) When the doors are copied the tags aren't 3) I can't copy room definitions, room tags, furniture... Am I using the wrong method?
And another thing. I design the stairs using boundaries and then specifying risers. In the end the stair does not touch to the next floor. Is there a way I can assure the stair is correctly placed?
I think it is obvious I'm a beginner. I would appreciate some help from experienced users.
