structural column and analitical model
    how do I adjust my pillar fork, with the analytical model?
    I wish that the analytical model would fit to the two arms of the fork!
    a r c h i t e t t o d a v i d e f a c c h e t t i
    S t u d i o T e c n i c o F a c c h e t t i
    a r c h i t e c t B I M m a n a g e m e n t
    http://www.studiofacchetti.com/
    The analytical model is a 1 for 1 kind of element. If you want an AM for this column I would make it out of 3 columns as that is what it would be to any analytical package.
    Erik Snell, P.E.
    Factory Worker (Principal User Experience Designer)
    I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
      but in reality it's only one Column
      Revit, into the editor's familiey, does not provide any tool which allows you to draw the "wires" analytical?
        It's not only if we provide it. It's if our analytical partners read the lines via our API. You can create additional lines when modeling in-place, but no one reads these elements in their links. They just don't know what to do if someone modifies this element in their applications. You could try nesting but once again your results may vary depending on your 3rd party analytical package.
        Erik Snell, P.E.
          ok thank you very much for the comprehensive answer! but it will be also implemented some update or release this feature?
