Hello. I keep on having this problem with my custom grids: When i try to apply a pattern on a custom grid that i create on a surface of a mesh, it won't place all the panels
(it works only when i set the layouts of the U and V grids to "fixed distance" ) Is the surface too complicated? or is the grid's fault ? I do not understand..
I tried to represent the problem in this image:
Thank you.
Thank you.
