Is there a way to override the phasing graphics in a view? In our plans we like to show existing walls as hatched, but in our interior elevations we like to see the walls with no hatch. I have tried using a VG override on cut patterns, but it doesn't seem to work for phasing graphics.
Object hatches and phasing
Originally posted by stl4310 View PostIs there a way to override the phasing graphics in a view? In our plans we like to show existing walls as hatched, but in our interior elevations we like to see the walls with no hatch. I have tried using a VG override on cut patterns, but it doesn't seem to work for phasing graphics.
Since it´s only the surface pattern that are getting turned off, you´ll still see the cut pattern in plan views, and no pattern in elevation views.Attached FilesKlaus Munkholm
So you want the cut pattern on in plan views and exterior elevations, and off in interior elevations ?
If that´s the case, your looking at some manual work one way or another.
- Manually pick the existing walls in the interior views, and override graphics by view.
- Create a Yes/No project parameter, e.g. "Is Existing" and apply it to the Wall category. Manually check the "Is Existing" box for all existing walls (should be rather easy in a view only displaying existing phase) and create a View Filter that relates to Walls and the "Is Existing" parameter...
- Accept the outcome as it is, and move on... ?
Is there a way to create a graphic override on phasing?
For instance, I have set all of my existing walls (through the phasing dialogue)...August 12, 2011, 08:40 PM -
When demoing a CMU wall is there a way to have the hatch show as demolished as well or just the exterior lines?February 21, 2012, 02:18 PM
In the olden days, we used to differentiate existing and new building elements with a line-based hatch to denote the material and a solid hatch in the...June 12, 2011, 03:24 PM
Steps to reproduce:
In a new project from any OOTB template (and probably some of your custom ones as well):
- Create a wall in
February 9, 2015, 01:15 AM -
Quite a title imho, but I've noticed something weird when doing phases in a project. Tested in our company template, version 2014 and 2015, and a clean...March 13, 2015, 12:20 PM
