I just want to print sheet which is in the revit (A1) but margings appears, i tried everything in printer settings, no margnis, 100% zoom etc, and always there is a margin or drawing is too big, yes i am sure its A1 format paper. If i just select print sheet, i guess it will be same with useless margins.. tips please
Printing problem, margins..
actually it was crop view problem, somehow i made it tu minimum so it could fit to sheet, and margins died, yeah. hell yeah. Good luck you today all my friends, boss was impressed and he wanted me to have a job during summer, because i was in internship. **** yeah. Thanks to this forum i am progressing as hell.
Hi there.
I am having problems when plotting an A0 to a HP 500 designjet plotter. I have the page set to centre (Screen Capture 1) yet...December 6, 2011, 05:34 AM -
If i choose to select a set of sheets from a project and send to a printer, occasionally one plan will be printed more than one time. i.e sheet A1.01,...December 3, 2015, 09:09 PM
Hi everyone,
I've been creating a drawing template on Revit but when I go to print on the T610, it doesn't print to the full width of the paper...-
Channel: Tutorials, Tips & Tricks
November 20, 2012, 03:00 PM -
When printing to large format PDF "some" machines give the "Setting incompatible with printer" message when they should be OK....February 25, 2014, 11:04 PM
Applies to: - All Verticals
New Feature / Problem:
Print setup varies per sheet size, function etc. Publishing a set of sheets requires...-
Channel: 2011 Archive
September 8, 2011, 02:47 PM -
