Is it possible to move floor layers manually like i can do with walls?
Modifying floor layers
You can select the layer and click the up and down buttons. That's about it.Martijn de Riet
Yes and no
You cannot Unlock layers of floors like you can walls (see attached)
You can however use the 'Join Geometry' tool to join floors and walls which will order the intersection based on the 'function' set in the 'Wall Type' dialogue. (see attached)I used to be high on life, until I realised it was cut with Morons.
Combating ignorance daily through learning.
Bangobeat, there are at leat 2 options:
1) A true 3D solution : make the finish floor a separate floor entity, and adjust the sketch in plan view as necessary.
2) A 2D solution: use View > Edit Cut Profile, to "fix" your section view, modifying the boundaries of the floor finish layer.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by bangobeat View PostTell me more how you do it, concrete wall just goes on whole floor, not on the concrete slab..
THe trick here is setting the right priorities to Wall and Floor layers. Basic groundrules:
- The primary rule in deciding which layer cuts which is the Function (structur > substrate > etc..). The higher in ranking order always cuts the lower when joined.
- Layers inside the Core Boundary always cut layers outside the CB with the same "strength"
It seems to me you need to review the assignment of Function and placement in relation to the Core Boundary for both Wall and Floor to make this work.Martijn de Riet
To Clarify,
There are 6 'Function Types' from "1 Structure" to "Finish 2".
These determine the joint 'hierarchy' and how the join is created.
To activate the join, use the "join Geometry" tool. Alternately click 'yes' when completing your floor and prompted "would you like to join geometry and cut the overlapping volume out of the wall(s)?"I used to be high on life, until I realised it was cut with Morons.
Title says it all. See the examples.
I created the floor, extended into core of wall. The linework is correct, but my wall still passes...July 14, 2011, 03:38 PM -
anyone know why the floor layers doesnt appear in the left side ?
...December 14, 2014, 09:40 PM -
Hello every one i can not get in revit on layers this is impossible layers mean that i can organize everything in the programme and hide layers that...August 18, 2011, 07:06 PM
I'm modelling up balconies for a residential project and I want to have the substrate layer only slopped, not the finished layer which is what happens...June 29, 2016, 04:41 PM
I'm drawing an existing structure where I want to separate a floor construction into two parts; the Concrete slab & DPM will be retained and the Insulation...September 26, 2014, 02:10 PM
