Plumbing Piping Insulation
    Is there a way to add insulation to plumbing piping in Revit 2013? All instances for adding insulation are grayed out? Any suggestions?
    Hi TeeterRevit, You must choose the pipe by clicking on it, then the tool is active, after activating the ADD INSULATION tool you should choose the insulation thickness, hope this helps, regards.
    E.A Poe
      You might have no insulation types defined... especially if you upgraded the project from 2012. I had something similar happen.
      If there is nothing in the project browser under Families->Insulation then find a project or template that does have it and copy paste into your project.
        After changing views to a working plan view the add insulation tab was highlighted and I added my thickness. Is there a way to preset a insulation thickness to all pipes that will be drawn? OR do you have to add as after piping as been drawn?
          Hey Guys well i think that in walls where water system accessories are to be placed, insulating material must be set up first. When water system in external surfaces, set up the insulating material behind the pipe joints, between the pipe joints and the external.Thanks!
          http://www.wecleardrains.com.au/
          • Can not delete insulation off pipework
            Hi
            i have taken over a job which has all the pipework with insulation on, I need to work and make changes, I have removed the insulation, but it...
            March 12, 2019, 03:39 PM
          • Pipe Insulation
            Hello
            As you can see i'm trying to insulate the piping system and everything is fine, but when i want to insulate the header (collector), the end...
            July 26, 2018, 07:26 AM
          • Pipe Insulation for Tees - Garbage!
            Alright, the title of this thread is just my frustration over Revit's insulation for tees.
            They look like big triangles. Has anyone overcome...
            June 13, 2015, 04:59 PM
          • Insulation
            If you use the insulation tool in Revit MEP 2012, then the insulation is over the whole length of the selected pipe. Is there an way that the insulation...
            August 23, 2011, 12:52 PM
          • Automatic placing insulation
            The last couple of days have i been placing insulation on ducts and pipes. It was a not the best time of my life. I then thought to myself if it was possible...
            January 11, 2017, 01:45 PM
