Is there a way to click on a wall's endpoint and tell it to move a specific distance, without moving the entire wall?
If you click on an endpoint, and drag the dot, there doesn't seem to be a way to specify a distance to stretch the length of the wall. If you click move, and then tab to the end of the wall, I've had the entire wall move, and I've had the end of the wall stretch as desired. If the wall is joined at the opposite end then it does allow you to stretch the end of the wall. Temporary dimensions don't seem to work either as it tends to move the entire wall.
Maybe I'm way off, but it'd be great to click on the blue endpoint dot and tell it how far to move, not how long to make the entire wall.
