Hello forum readers
I am the leading developer of the 4Revit add-in. I would like to plan the medium-term development. Therefore I would like to get some Opinions from you. I am located in Central Europe so my Ideas are inspired by the local requirements.
1. I would like to solve issues with the waste water and excavation plans. Are these problematic fields for you also? Or are they not important at all?
2. The goal for the wastewater solution should not be to model in 3D. That is what Revit MEP is for. I would like to concentrate on the topology. That should allow to get information about the amount of waste water for a pipe segment, the objects (toilets, bath tubes, etc.) connected to the segment, the water flow through the segment etc. - Any comments?
3. The excavation plan should support to model a terrain along existing 3d elements like the edges of the building pads to model the excavated terrain. At the same time, 2d? signatures should be added to the excavation plan. - Any comments?
Thank you for your time and for letting me know your thoughts.
Have a nice time with Revit
