If it's any help, when I do these (Mansard?) types of roof with sloping sides and 'flat' top I sometimes use the Parameter called Cutoff Level in the roof by footprint properties to limit the top level of the roof.
You need to create a level so that it appears in the drop down list that appears in the Cutoff Level parameter when selected, but then you can move that level up and down in Views and so control the top level of the roof interactively.
First off, just wanted to say hello and I'm looking forward to learning a lot from everyone on here. Now on to the question. I'm trying to add a roof...
Maybe I'm doing this wrong, but I thought the roof cutoff level cut the TOP of the roof, leaving a hole. I need to create a mansard roof and figured...
