Inspired by this thread, I´ve created the following short video to explain how to apply parametric finish materials to Revit Families.
Note, this may not work in RST and MEP, and it does NOT work in Revit 2012 either (A fix for 2012 should be on its way)
This is great for applying different finishes to the same object. e.g. a window frame made of "Wood" but with "Paint 1" on the interior side and "Paint 2" on the exterior side. (In this case you´d need two "Finish Materials")
Basic steps:
:beer:
Basic steps:
- Create a "Material" Parameter (If it doesn´t already exist)
- Create a "Finish Material" Parameter
- Apply the "Material" parameter to the actual geometry
- Use the paint tool to apply the "Finish Material" (Param) to the desired faces of the geometry
:beer:
