I've had a good search through the forum but cant find my exact problem...
I have linked one revit file into another, but when i try to "insert from file > insert views from file" the sheets i need are not showing up in the dialogue. However, drafting views and other sheets from the linked model (which i DON'T need) are showing up ...what am i missing?:banghead:
edit:
from autodesk help :
If another project contains a view or sheet that you want to reuse in the current project, use the Insert Views from File tool. This tool can copy the following types of views into the current project:
Schedules
Drafting views
Rendered images
Sheets that contain only drafting views
does this mean i'm going to have to set up elevation views all over again just so i can import the 2d elements?
edit:
Schedules
Drafting views
Rendered images
