I have a mezzanine level that I'm working on. There is a mechanical room with four walls and then the rest has NO walls -- just hand rails.
I placed the walls as "Room Bounding" and placed room separator lines at the hand rail/floor edge locations. But when I place the rooms, it tells me there are no boundaries. For the mechanical room, I even went so far as to make the walls CROSS each other to be sure there were no gaps -- it STILL couldn't find the boundary.
I've attached my file (I zipped it up because unzipped, it's 10 mb and zipped it's less than 2mb).
Does anyone have any ideas what this could be?
TIA!
P.S. In the attached file, I've removed everything not related to the mezzanine in an effort to try and make the file smaller (after doing a save as on my file to make this one). I've also used View Visibility to turn off the handrail so the room separators are easier to see.
TIA!
