Interior Elevation Properties
    Curious where Interior Elevations get there settings.
    When you place an interior elevation it knows its bound by the walls immediatley either side and bound by associated level above and below.
    Anybody know if settings are accessible?
    I assume they are hard wired.
    Mark Balsom
    Maybe "behind the curtains" the interior elevation tool makes use of the same code that the Room tool uses to find a room within walls, but in this case, even if the walls are not room bounding, and even if there is not a room entity created within the walls, still the extents of the interior elevation stop at the interior face of the walls. That is amazing, and very interesting.
      Thanks Alf, like I said just curious as they are quite clever little creatures and I assumed they were hidden settings.
      Mark Balsom
