How do I wrap a tread around the corner? Nothing I'm trying is working.
Wrap Stairs Around Exteior Corner
Simply use risers and boundaries. Sketch the desired form...Martijn de Riet
It still won't work. I think it's because the boundary is in line with one of the risers. The top riser doesn't reallyl make the turn.
Now the stair is disappearing, even though it's the exact same settings as 4 other stairs. Those are all showing up. :banghead:Last edited by dzatto; May 1, 2011, 07:38 PM.Dan
yes it does...
but you need the "end with riser" uncheckedMartijn de Riet
I must be retarded. I got it to work (thanks for the sketch) , but it's backwards. So I flipped it and it disappears. WTF???Attached FilesLast edited by dzatto; May 1, 2011, 08:55 PM.Dan
ehhhhmmm, did you by any chance constrain something?
Couldn't you just copy in mine?Martijn de Riet
Originally posted by mdradvies View Postehhhhmmm, did you by any chance constrain something?
Originally posted by mark b View PostSelect your stair and look for the tiny blue arrow to reverse directionDan
Hmmm, didn't notice that. Yeah, image 2 is what I need. Let me see if that return is what's messing it up.
:banghead: I don't know what's going on. I can't do it!!
I've tried drawing the boundary in both directions, it won't flip the stairs.Last edited by dzatto; May 1, 2011, 10:58 PM.Dan
I'm trying to add a landing by lengthening a riser, then drawing an additional boundary line to flatten that stringer. Why do I keep getting the error...August 12, 2011, 05:18 PM
I have to create a stair run of 2 risers. Since the boundary of the risers isn't square (one side is against an angled wall, the other a curved wall)...May 27, 2012, 04:47 PM
Firstly, a few general matters.
Given the change in the stairs with stairs by components etc, one needs to use the new templates which...March 27, 2012, 10:09 PM -
hi, need some help on how to model this type os stairs...December 24, 2019, 04:58 PM
when i number stairs it looks like that .. a non stair tread got a number !!!
anyone know what happened here ?
...November 11, 2014, 03:35 AM
