I just installed Revit Architecture 2012 student. Is there a higher resolution material library than the medium one? I searched google but could not find any info. Thanks.
Revit "high" quality material library?
No, there is the 'base' low resolution one and the newer 'medium' one. There's only two.
If you need a 'high' resolution library then you might want to consider using something else for your rendering. The Medium images are actually much higher resolution than 90% of people will ever need for most Viz work. Higher resolution images, while totally usable, are gonna not really help that much with image quality unless you're rendering HUGE images with Revit.
At that point you'll probably want to look at other engines or systems to get the results you want efficiently. Revit uses the same rendering engine as Max, Mental Ray, but Max gives you a whole lot more control. And you'd need that if you're doing work at that scale!Jeffrey McGrew
Architect & Founder
I'm doing all my renderings in Revit right now, which is okay. I'm wondering what other programs are out there that are worth looking into.
Channel: Rendering and Gallery
August 8, 2013, 08:49 PM -
Hello, producing this rendering but not satisified at it. (still using revit 2008 to modelled and render). how can i make it look more realistic? is it...
October 25, 2016, 05:51 AM -
I just crashed Revit (display driver shut down and recovered). It's happened before. But, this time, I got the attached message upon restarting Revit....May 9, 2012, 02:58 PM
I've been messing around with rendering on and off for a year or two. Attached are two renderings. Both are 150 dpi 4" wide. One is done on the medium...
June 10, 2011, 03:43 PM -
Asking here rather than the rendering forum because this will most likely end up needed some family manipulation / adaptive components.
...November 4, 2013, 05:17 PM
