before I begin recreating my schedules in the other two project files for the three building job I'm working on, is there a way to get a schedule from one rvt file to another? Transfer Project Standards doesn't seem to have a schedule item on the list. Most of my schedules are in my template but the one I need to transfer was created while I developed the content in Bldg 1 and will only be used for this project. Not a big deal to recreate it twice but I was curious about if there is a way to do it with the Easy button...
Schedule from one project to another?
Dave,
in this case Schedules are more like Drafting Views. You pull them over via Insert > Insert from File > Insert Views from File. You get a File dialog and choose the file you want to pull from, and then a list of everything available to insert.
Why you can't insert other "views" that would then "look at" the model on the receiving end, I don't know. That could be a slick improvement down the road.
Gordon
Originally posted by Dave Jones View Postbefore I begin recreating my schedules in the other two project files for the three building job I'm working on, is there a way to get a schedule from one rvt file to another? Transfer Project Standards doesn't seem to have a schedule item on the list. Most of my schedules are in my template but the one I need to transfer was created while I developed the content in Bldg 1 and will only be used for this project. Not a big deal to recreate it twice but I was curious about if there is a way to do it with the Easy button..."Two possibilities exist. Either we are alone in the universe, or we are not.
Both are equally terrifying." - Arthur C Clarke
Or you open the project you want them from, select them in the PB, copy to clipboard. Then go to the new project, open a drawing view (plan view, elevation, 3d. Basically anything that views the model), Paste (cntrl-v). And you're done...Martijn de Riet
Good Morning!!!
Has anybody ever copied a view with it's settings from one file to another? I did! I would create a new schedule and then...October 23, 2012, 07:54 AM -
Hello Everyone,
I am having an issue on inserting from a file drafting views.When I get the dialog box that asks which view and only checking one...May 11, 2011, 07:26 PM -
Insert from File allows us to import views from another project, views like schedules, drafting views or even sheets that contain either. It is biased...
Channel: Blog Feeds
March 29, 2015, 03:15 PM -
Hopefully the title of this questions explains it well enough BUT....
Currently on a new project that would benefit by bringing in elements from...May 2, 2018, 09:55 PM -
I am not able to use this feature anymore. Whenever I try to insert views, i will pick the project file, and nothing will happen. I have tried restarting...March 2, 2021, 01:39 PM
