Scaling 3D Images on a Sheet
    When I bring a 3D image onto a Sheet the scale varies from postage stamp size to half the sheet.
    How can I scale the 3D image up or down. I am running Revit 2012.
    Thank you in advance for guidance.
    Are you talking about 3D perspective view? Select the view on the sheet and use Size Crop on ribbon (assuming that it is the same in 2012 as in the newer versions, can’t remember).
      I think he may be referring to the distance from the camera to the subject. This is set when creating a new 3D camera view. Search the forum or Revit help files on using the view cube to navigate in a 3d view. Sorry I don't have a better answer right now but I'm flat out...
      3D Views - WikiHelp
      and welcome to the forum!
