Just curious, how is everybody else dealing with cornices, without splitting walls.
Cornice Question
What do you mean? I usually create these as a Wall Sweep.Martijn de Riet
Originally posted by mdradvies View PostWhat do you mean? I usually create these as a Wall Sweep.
returns, overlap and give errors. Doing returns around wall ends is slow and painful.
I personally use a workaround by using model lines locked around the perimeter of the tops of walls
then use a cornice profile set with Fascia Poperties (fascias and Gutters snap to model lines).
Placing Cornice once model lines are in place is a breeze, they join just like fascias. just pick the lines,no corner problems and they wrap around wall ends.
Like I said I am curious how others work with them.Attached FilesMark Balsom
You're right in the clunkyness. It sucks sometimes. But you should have just posted this workaround in the tips and tricks segment! It's great!Martijn de Riet
But I always do schedule them... And I hate In Place Families so I try to avoid them as much as possible...Martijn de Riet
Normally yes, but if you set the workplane for the model line to the top of the wall, you can actually pick the proper wall sides and it will place the line. So no drawing and stuff. This is about 95% faster then my previous workflow.
Come to think of it, that would probably also work for inplace families...Martijn de Riet
In place family is not as flexible. been there tried that !
The beauty of model lines is delete the model line that cornice segment is gone, add more model lines to continue chain.
With model lines on gable ends (where ceiling is flat) just run a line from top plate to top plate on either side to continue cornice level across gable end.
my work flow is
1. Create a line style as bright and heavy as you like called cornice ( I use red,4 weight), set work plane to top of wall (or desired plane).
2.Then work in thick line mode, this makes it easy to see the red lines as you pick the desired wall edges. Use Pick mode Lock obviously, and select what you need.
3.I then place ONE length of Cornice (Fascia). Then select one line and section of cornice, hit Temporary Isolate Category so all you see is your lines and cornice, then click away.
4.When the job is complete I go and reset Cornice line Style to Black-1 line weight and then the model line disappears into the top of the wall.Attached FilesMark Balsom
So, doing some tile wainscot. Come to find out wall sweeps behave really poorly when wrapping around a wall corner. Have to use two pieces to achieve...November 30, 2011, 08:42 PM
Enclosed are two shots of a stacked wall type. Not the way I'd design a wall-I'm just modelling it. Maybe a stacked wall is not the...February 3, 2014, 10:54 PM -
<Lurk mode off>
Be interested to see if anyone has ideas / suggestions on how to handle the following:
...March 6, 2013, 12:46 PM -
This parapet cap trimmed itself automatically
at the top of all the walls except these two
corners. How do I trim them?...November 29, 2019, 04:35 AM -
I've recently decided to go full-on with Revit, rather than dipping my toe in out of it, and I'm enjoying making some (slow) progress. But I keep getting...April 6, 2018, 09:28 PM
