Curtain Wall - finish wrapping @ insert?
    Is it possible to get a curtain wall to allow finish materials to wrap at inserts, similar to inserting objects into walls?
    Only way that I know of, is to create a window family with nothing in it but the opening and the "Defines Closure" ref. planes, place that on the walls to make the cut, and then add the curtain walls in the opening created by the "window"
    :beer:
      Yup, that's the only way I know of too.
        In 2016 we just found that you can place a wall opening end to end of each curtain wall, and it will force the wraps
