What Revit Wants: Copy Path and Filename in Windows XP 64-bit
    In Windows 7, I constantly used Shift+right click to access the Copy as Path option.
    To enable this in Windows XP, you can use:
    Path Copy Copy
    This works on 64-bit (x64) Windows XP too.
    I tried some other tools (like PathCopyEx), but Path Copy Copy seems more reliable. In the settings, you should enable the "Add quotes around copied paths" option:
    Author of What Revit Wants
