Can't seem to figure out a way to model a Rail Car Track down the mountain side. Its going to take me hours to move each piece manually to match the drastic change in the topo. I'm using 2011, does anyone know how to attach or drape objects to the topo? I would rather this process not take an entire day of work, and then have to do it again if the track location changes.
Modeling a rail car track down the side of a mountain.
Revit can't do it.
However, Eagle Point Land Cadd has an application called Site Works that can do it, using Massing. You can sweep a profile up a curved/sloping path. Downside is it costs $2500............LOL.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Well, railroads, perhaps. But it can't do simple parking lot stalls on a sloped toposurface--just ask them. Had them try to do it live in a webcast the other day--no go. LOL. See my Wishlist post on that topic. I need parking lots and striping with sloped topo on every project.
Railroads? Maybe once in 50 projects? And even then, I'd probably just do it in 3dsMax.Cliff B. Collins
I meant I'd do the RR track in Max, not the parking stripes.
But back "on track"--pun intended--to the OP question--I bet Phil Read could do the RR track with a custom Railing?!!!Last edited by cliff collins; April 28, 2011, 04:41 PM.Cliff B. Collins
I bet that it could also by done with Vasari and Nucleus.
Should be really easy to get the hill side into Vasari, and then use Nucleus physical phenomena form finding to drape a shape over the hill side (Adjusting gravity to make it a smooth shape)
And with adoptive components hosted on the new draped shape, you could create the Rail... ?
Ok ok, the railing solution is probably easier to most people, just saying that it´s possible :beer:Klaus Munkholm
I've done this before, but been a while.
Have a large project, would like to show a few blocks worth of streets/roads in a site plan surrounding...May 31, 2016, 03:06 AM -
Hi guys,
We had a survey done for a new house site and the surveyor hasn't quite picked up enough terrain which is resulting in 3/4 of the...November 20, 2019, 03:11 AM -
I am asking anyone who thinks they have a site topography or hardscape modeling challenge to submit them to me so I could determine if it is possible...August 9, 2013, 10:49 PM
I have a Revit project that has a linked topo survey in. I am trying to created a section but no matter how much I change the far clip...June 23, 2017, 12:43 PM -
Hi all,
Does anyone have any good suggestions for modelling roads and footpaths on uneven topo surfaces? My topo surface slopes down roughly...September 10, 2016, 09:54 PM
