Positive Negative offset
    I want to create a family that has geometry that can be offset from a centerline with a positive or negative value. Essentially, moving an object to the inside or outside of wall based on the centerline. Obviously, it won't let me enter a negative value, so what's the way to do this?
    It can be done like shown in the attached illustration and .rfa
    You´ll not be able to offset further than the "fixed dim" so be sure to set that value high enough.
    Also, you might wanna adjust the formula, to take the size of the offset geometry in consideration. :beer:
      Actually, as you probably want to adjust for the object size, i might as well provide the formula to do that
        Try here:
        http://dorevit.blogspot.com/2008/01/...-families.html
          Thanks everyone, you all rock. My door family is finally dialed in! Parametric door panels, door frame location within the wall, door width, height, plan swing parameter, frame width and depth. And I believe it's all pretty user friendly.
            my god thats a large file size... my biggest family is a little over 600k
            -Alex Cunningham
              well, some are just bigger than others...get over it
