Right, you can't override this.
HOWEVER: these cut lines, and also the Common Edges btw, are ALWAYS in lineweight 2... So you'll need to adjust the assigned lineweights off all system families in the Object Style to match this, and then assign the thickness you want to Lineweight 2.
I'm guessing that in your case you set the Walls to have a Lineweight 1 (which is by the way also reserved for the hatch patterns)
as in the attached image I am trying to cut profile a concrete tray deck floor. the floor is a build up of concrete and a profile added to the bottom...
I’ve used the Edit Cut Profile tool in plan to tidy upa troublesome wall join and as you can see in the attached it all looks as it should in Fine Detail...
Checked and double-checked this little bugger, and it seems to do the right thing on other items, except for this beam. Doing view > cut profile, create...
I'm stymied on this one. I have a wall sweep with my EIFS profile and it behaves correctly, however in section I need to use a Cut Profile override and...
