RFOBenchmark 2012 results
    Please post your RFOBenchmark results for the 2012 products here.
    Comments and suggestions should be made in the RFOBenchmark thread.
    Thanks!
    Gordon
    Pragmatic Praxis
    I am going to kick things off with some 2011 vs 2012 comparisons I did.
    In general, Revit 2012 is slower than 2011. In the model creation portion of the benchmark, 2012 is a little faster where curtain walls are concerned, and quite a bit faster at exports. Everything else is a little slower to a lot slower, which is disappointing. Rendering looks to be a little faster, but nothing earth shattering. But hardware accelerated model manipulation is faster. And with all views now supporting Shadows & Ambient Shadows, that is a welcome improvement.
    Of course the Consistent Colors comparison is not apples to apples. In 2011 there are no shadows, in 2012 there are. And yet, 2012 is only a little slower with shadows than 2011 without. Nice, that. Look for a more detailed report on view performance and GPU issues in the near future.
    Some things to consider.
    1: This is a comparison of the initial release of 2012 with the second service pack of 2011. I don’t have any data for the initial release of 2011, so perhaps we can expect 2012 to catch up half way through it’s life? Still disappointing, but gotta be realistic.
    2: Truth is, most time spent using Revit is sitting and thinking. The time I notice performance the most is when manipulating the model, and in that respect 2012 looks to be a bit faster. We'll see if other folks see similar results.
    Gordon
    2011 vs 2012 comparison on two Core2 machines
    Code:
    Machine #1: Core2 Quad Q9650 @ 3.00GHz, GeForce GTS 250
    Model creation and view export benchmark
    5.33	        9.00	         opening and loading the custom template
    11.00	        12.00	         creating the floors levels and grids
    29.33	        32.00	         creating a group of walls and doors
    47.67 	        55.00	         modifying the group by adding a curtain wall
    26.67	        22.00	         creating the exterior curtain wall
    13.00	        15.00	         creating the sections
    14.00	        11.00	         changing the curtain wall panel type
    46.00	        30.00	         export all views as PNGs
    55.00	        46.00	         export some views as DWGs
    248.00	        232.00	         Total
    Render benchmark
    434.33	        413.00	         render
    GPU benchmark
    10.00	        6.00	         refresh Hidden Line view - with hardware acceleration
    5.00	        6.00	         refresh Consistent Colors view - with hardware acceleration
    7.00	        6.00	         refresh Realistic view - with hardware acceleration
    10.00	        9.00	         rotate view - with hardware acceleration
    61.67	        57.00	         refresh Hidden Line view - without hardware acceleration
    7.33	        57.00	         refresh Consistent Colors view - without hardware acceleration
    58.67 	        55.00	         refresh Realistic view - without hardware acceleration
    85.67	        90.00	         rotate view - without hardware acceleration
    Machine #2: Core2 Quad Q6600 @ 2.40GHz, GeForce 8600 GT
    8.00	        11.00	         opening and loading the custom template
    15.00	        19.00	         creating the floors levels and grids
    39.00	        44.00	         creating a group of walls and doors
    61.00	        71.00	         modifying the group by adding a curtain wall
    29.00	        28.00	         creating the exterior curtain wall
    17.00	        20.00	         creating the sections
    16.00	        14.00	         changing the curtain wall panel type
    54.00	        37.00	         export all views as PNGs
    73.00	        62.00	         export some views as DWGs
    312.00	        306.00	         Total
    Render benchmark
    583.00	        559.00	         render
    GPU benchmark
    10.00	        9.00	         refresh Hidden Line view - with hardware acceleration
    6.00	        8.00	         refresh Consistent Colors view - with hardware acceleration
    7.00	        7.00	         refresh Realistic view - with hardware acceleration
    11.00	        11.00	         rotate view - with hardware acceleration
    76.00	        74.00	         refresh Hidden Line view - without hardware acceleration
    8.00	        74.00	         refresh Consistent Colors view - without hardware acceleration
    75.00	        72.00	         refresh Realistic view - without hardware acceleration
    123.00	        119.00	         rotate view - without hardware acceleration
    Pragmatic Praxis
      Code:
      RFO Benchmark v04.25.2011 (RAC 2012) run at 27-04-2011 21:18:09
      RevitForum.org
      13,00	 opening and loading the custom template
      13,00	 creating the floors levels and grids
      32,00	 creating a group of walls and doors
      50,00	 modifying the group by adding a curtain wall
      22,00	 creating the exterior curtain wall
      16,00	 creating the sections
      10,00	 changing the curtain wall panel type
      28,00	 export all views as PNGs
      41,00	 export some views as DWGs
      225,00	 Total
      Render benchmark
      312,00	 render
      GPU benchmark
      5,00	 refresh Hidden Line view - with hardware acceleration
      5,00	 refresh Consistent Colors view - with hardware acceleration
      4,00	 refresh Realistic view - with hardware acceleration
      7,00	 rotate view - with hardware acceleration
      55,00	 refresh Hidden Line view - without hardware acceleration
      55,00	 refresh Consistent Colors view - without hardware acceleration
      53,00	 refresh Realistic view - without hardware acceleration
      150,00	 rotate view - without hardware acceleration
      MACHINE SPEC:
      OS: Microsoft Windows 7 Professional  64-bit
      CPU: AMD Phenom(tm) II X6 1090T Processor
      Max Clock Speed: 3,20 GHz
      Number of Processors: 1
      Number of Logical Processors: 6
      Total Physical Memory: 16,00 GB
      Bank0/1: 4,00 GB @ 1333 MHz
      Bank2/3: 4,00 GB @ 1333 MHz
      Bank4/5: 4,00 GB @ 1333 MHz
      Bank6/7: 4,00 GB @ 1333 MHz
      Graphics Card: ATI Radeon HD 5700 Series
      Graphics RAM: 1,00 GB
      Driver version: 8.782.0.0
        Code:
        RFO Benchmark v04.25.2011 (RME 2012) run at 4/28/2011 1:18:09 PM
        RevitForum.org
        3.00	 opening and loading the custom template
        7.00	 creating the floors levels and grids
        22.00	 creating a group of walls and doors
        40.00	 modifying the group by adding a curtain wall
        14.00	 creating the exterior curtain wall
        9.00	 creating the sections
        7.00	 changing the curtain wall panel type
        18.00	 export all views as PNGs
        30.00	 export some views as DWGs
        150.00	 Total
        Render benchmark
        273.00	 render
        GPU benchmark
        4.00	 refresh Hidden Line view - with hardware acceleration
        3.00	 refresh Consistent Colors view - with hardware acceleration
        3.00	 refresh Realistic view - with hardware acceleration
        5.00	 rotate view - with hardware acceleration
        35.00	 refresh Hidden Line view - without hardware acceleration
        35.00	 refresh Consistent Colors view - without hardware acceleration
        35.00	 refresh Realistic view - without hardware acceleration
        51.00	 rotate view - without hardware acceleration
        MACHINE SPEC:
        CPU: Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz
        Max Clock Speed: 4.19 GHz
        Number of Logical Processors: 4
        Total Physical Memory: 5.99 GB
        Bank0/1: 2.00 GB @ 1066 MHz
        Bank4/5: 2.00 GB @ 1066 MHz
        Bank8/9: 2.00 GB @ 1066 MHz
        Graphics Card: NVIDIA GeForce GTX 470
        Graphics RAM: 1.25 GB
        Driver version: 8.17.12.7061
        Kaylin Richardson
        Sr. CAD Tech
        http://www.brownengineers.net/
          I found a small loop hole in the internet filter. Working in RST
          Code:
          RFO Benchmark v04.25.2011 (RST 2012) run at 4/28/2011 12:36:38 PM
          RevitForum.org
          5.00	 opening and loading the custom template
          61.00	 modifying the group by adding a curtain wall
          21.00	 creating the exterior curtain wall
          14.00	 creating the sections
          10.00	 changing the curtain wall panel type
          29.00	 export all views as PNGs
          230.00	 Total
          Render benchmark
          415.00	 render
          GPU benchmark
          3.00	 refresh Hidden Line view - with hardware acceleration
          4.00	 rotate view - with hardware acceleration
          48.00	 refresh Realistic view - without hardware acceleration
          94.00	 rotate view - without hardware acceleration
          MACHINE SPEC:
          OS: Microsoft Windows XP Professional x64 Edition 64-bit
          CPU: Intel(R) Pentium(R) III Xeon processor
          Max Clock Speed: 2.67 GHz
          Number of Processors: 8
          Total Physical Memory: 7.98 GB
          : 2.00 GB @ 1333 MHz
          : 0.00 GB @  MHz
          Graphics Card: NVIDIA Quadro FX 1800
          Graphics RAM: 768 MB
          Driver version: 6.14.12.6570
          -Alex Cunningham
            Nice to see the overclocking effect in the same Q6600 of Gordon`s second Machine. (here overclocked from 2.40 to 3.52Ghz)
            Code:
            RFO Benchmark v04.25.2011 (RAC 2012) run at 4/29/2011 12:10:53 PM
            RevitForum.org
            8.00	 opening and loading the custom template
            13.00	 creating the floors levels and grids
            28.00	 creating a group of walls and doors
            46.00	 modifying the group by adding a curtain wall
            18.00	 creating the exterior curtain wall
            12.00	 creating the sections
            9.00	 changing the curtain wall panel type
            25.00	 export all views as PNGs
            47.00	 export some views as DWGs
            206.00	 Total
            Render benchmark
            379.00	 render
            GPU benchmark
            5.00	 refresh Hidden Line view - with hardware acceleration
            5.00	 refresh Consistent Colors view - with hardware acceleration
            4.00	 refresh Realistic view - with hardware acceleration
            7.00	 rotate view - with hardware acceleration
            46.00	 refresh Hidden Line view - without hardware acceleration
            46.00	 refresh Consistent Colors view - without hardware acceleration
            45.00	 refresh Realistic view - without hardware acceleration
            49.00	 rotate view - without hardware acceleration
            MACHINE SPEC:
            OS: Microsoft Windows 7 Ultimate  64-bit
            CPU: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz (OVERCLOCKED 3.52 GHZ)
            Max Clock Speed: 2.39 GHz
            Total Physical Memory: 4.00 GB
            BANK0: 2.00 GB @ 667 MHz
            BANK2: 2.00 GB @ 667 MHz
            Graphics Card: NVIDIA GeForce 8800 GTS
            Graphics RAM: 320 MB
            Last edited by Munkholm; April 29, 2011, 09:40 AM. Reason: added [ code ] brackets
              Same machine but temporary upgraded the video card from Nvidia 8800GTS 320MB to Nvidia 460GTX 1Gb. Same results...
              Code:
              RFO Benchmark v04.25.2011 (RAC 2012) run at 4/29/2011 5:46:23 PM
              RevitForum.org
              47.00	 modifying the group by adding a curtain wall
              206.00	 Total
              Render benchmark
              372.00	 render
              GPU benchmark
              5.00	 refresh Realistic view - with hardware acceleration
              MACHINE SPEC:
              CPU: Intel(R) Core(TM)2 Quad CPU    Q6600  @ 2.40GHz(OVERCLOCKED 3.52 Ghz)
              Graphics Card: NVIDIA GeForce GTX 460
              Graphics RAM: 1.00 GB
                My sad results, though it is a 4 year old machine (with a newer graphics card):
                Code:
                RFO Benchmark v04.25.2011 (RAC 2012) run at 5/2/2011 1:56:42 PM
                RevitForum.org
                16.00	 opening and loading the custom template
                18.00	 creating the floors levels and grids
                39.00	 creating a group of walls and doors
                59.00	 modifying the group by adding a curtain wall
                25.00	 creating the exterior curtain wall
                12.00	 changing the curtain wall panel type
                34.00	 export all views as PNGs
                54.00	 export some views as DWGs
                277.00	 Total
                Render benchmark
                531.00	 render
                GPU benchmark
                7.00	 refresh Consistent Colors view - with hardware acceleration
                61.00	 refresh Hidden Line view - without hardware acceleration
                60.00	 refresh Consistent Colors view - without hardware acceleration
                60.00	 refresh Realistic view - without hardware acceleration
                128.00	 rotate view - without hardware acceleration
                MACHINE SPEC:
                CPU: Intel(R) Xeon(R) CPU           X5365  @ 3.00GHz
                Max Clock Speed: 3.00 GHz
                Total Physical Memory: 16.00 GB
                : 4.00 GB @ 667 MHz
                : 4.00 GB @ 667 MHz
                : 4.00 GB @ 667 MHz
                : 4.00 GB @ 667 MHz
                Graphics RAM: -2,048 MB
                Interesting that the RME numbers are quite different (esp. opening and loading):
                Code:
                RFO Benchmark v04.25.2011 (RME 2012) run at 5/2/2011 2:56:37 PM
                RevitForum.org
                42.00	 creating a group of walls and doors
                62.00	 modifying the group by adding a curtain wall
                22.00	 creating the sections
                13.00	 changing the curtain wall panel type
                55.00	 export some views as DWGs
                284.00	 Total
                Render benchmark
                548.00	 render
                GPU benchmark
                61.00	 refresh Consistent Colors view - without hardware acceleration
                62.00	 refresh Realistic view - without hardware acceleration
                127.00	 rotate view - without hardware acceleration
                Haven't installed RST 2012 yet.
                  Colleague's machine, also 4 years old:
                  Code:
                  RFO Benchmark v04.25.2011 (RAC 2012) run at 5/2/2011 3:10:39 PM
                  RevitForum.org
                  21.00	 creating the floors levels and grids
                  52.00	 creating a group of walls and doors
                  84.00	 modifying the group by adding a curtain wall
                  34.00	 creating the exterior curtain wall
                  26.00	 creating the sections
                  17.00	 changing the curtain wall panel type
                  46.00	 export all views as PNGs
                  74.00	 export some views as DWGs
                  362.00	 Total
                  Render benchmark
                  709.00	 render
                  GPU benchmark
                  8.00	 refresh Hidden Line view - with hardware acceleration
                  9.00	 refresh Consistent Colors view - with hardware acceleration
                  8.00	 refresh Realistic view - with hardware acceleration
                  12.00	 rotate view - with hardware acceleration
                  89.00	 refresh Hidden Line view - without hardware acceleration
                  89.00	 refresh Consistent Colors view - without hardware acceleration
                  89.00	 refresh Realistic view - without hardware acceleration
                  190.00	 rotate view - without hardware acceleration
                  MACHINE SPEC:
                  CPU: Intel(R) Xeon(R) CPU           E5335  @ 2.00GHz
                  Max Clock Speed: 2.00 GHz
                  : 4.00 GB @ 667 MHz
                  : 4.00 GB @ 667 MHz
                  : 4.00 GB @ 667 MHz
                  : 4.00 GB @ 667 MHz
                  Graphics Card: NVIDIA Quadro FX 1700
                  Graphics RAM: 512 MB
                  Driver version: 8.17.12.6779
                  Wow, that's an especially slow processor.
                    Result is a bit diasppointing, regarding the specs:
                    Code:
                    RFO Benchmark v04.25.2011 (RAC 2012) run at 03-05-2011 12:48:05
                    RevitForum.org
                    6,00	 opening and loading the custom template
                    9,00	 creating the floors levels and grids
                    23,00	 creating a group of walls and doors
                    41,00	 modifying the group by adding a curtain wall
                    15,00	 creating the exterior curtain wall
                    10,00	 creating the sections
                    7,00	 changing the curtain wall panel type
                    20,00	 export all views as PNGs
                    37,00	 export some views as DWGs
                    168,00	 Total
                    Render benchmark
                    251,00	 render
                    GPU benchmark
                    3,00	 refresh Hidden Line view - with hardware acceleration
                    3,00	 refresh Consistent Colors view - with hardware acceleration
                    3,00	 refresh Realistic view - with hardware acceleration
                    37,00	 refresh Hidden Line view - without hardware acceleration
                    37,00	 refresh Consistent Colors view - without hardware acceleration
                    38,00	 refresh Realistic view - without hardware acceleration
                    79,00	 rotate view - without hardware acceleration
                    MACHINE SPEC:
                    CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
                    Max Clock Speed: 3,40 GHz
                    Number of Logical Processors: 8
                    Total Physical Memory: 15,98 GB
                    BANK3: 4,00 GB @ 1333 MHz
                    BANK1: 4,00 GB @ 1333 MHz
                    BANK4: 4,00 GB @ 1333 MHz
                    BANK2: 4,00 GB @ 1333 MHz
                    Graphics Card: ATI Radeon HD 5450
                    Driver version: 8.812.0.0
                    And without virusscanner:
                    Code:
                    RFO Benchmark v04.25.2011 (RAC 2012) run at 03-05-2011 13:55:19
                    RevitForum.org
                    8,00	 creating the floors levels and grids
                    22,00	 creating a group of walls and doors
                    9,00	 creating the sections
                    8,00	 changing the curtain wall panel type
                    19,00	 export all views as PNGs
                    32,00	 export some views as DWGs
                    157,00	 Total
                    Render benchmark
                    248,00	 render
                    GPU benchmark
                    4,00	 refresh Hidden Line view - with hardware acceleration
                    4,00	 refresh Consistent Colors view - with hardware acceleration
                    37,00	 refresh Realistic view - without hardware acceleration
                    MACHINE SPEC:
                    Still a bit disappointing...
                    Simon
