Nothing I'm trying works. I'm sure there's an easy solution.
I created a railing to use as a fence. It has 2X12 railings top and bottom, with 2X12 "posts" on the sides. The intermediate balusters and rails are 1/2" x 1/2", creating a 6"x6" grid. So far, so good.
I also need to add a 4x12 baluster every 10' max along the fence line. I can't get it to work. What's worse is that's just a max dimension. If the fence line is only 16', then it will split it in half at 8'. It just can't go over 10' spacing. I've shown them in blue.
How do I do that in a railing?
