Joining Roofs Problem
I assume you are trying to run the small roof into the large roof. Select the small roof, select the line (the one you want to run into the other roof) uncheck define slope and make it a gable, then join to other roof will work.
Select join roof tool then select Gable edge then select main roof.Last edited by mark b; April 28, 2011, 01:35 AM.Mark Balsom
Hey all. I am hoping someone can help me with a roof. I basically have to gables that meet at the corner. I can't figure out how to draw this as one...January 4, 2017, 02:51 PM
Hi guys I have 2 problems! The first one is on the left part , if I remove the to end at the back of the brick, since the roof line is closer...October 9, 2018, 02:32 PM -
I am having trouble with merging the porch roof with the main bulding roof. I've attached the file an a screen shot. Any ideas?...August 24, 2018, 08:09 PM
I made a roof with a roof cricket made up of two roofs. The main roof is a standard sloped roof that slopes down to the roof cricket roof which I made...May 20, 2020, 06:36 PM
I am having issues creating this roof. I am currently using three different roofs, one for the front gable, one for the long gable, and one for the flat...January 27, 2011, 08:48 PM
