I would like to create outlets that show up in the wall base (created using the wall sweep). When I create a new reference plane they stick out from the wall several inches - not the 3/4" I specify in the family that represents the depth of my base. If I leave them on their existing reference plane they don't show up within the wall base. Is there a way to make the outlet distance from the wall editable?
outlets in wall base
Yep, same as the other thread. http://revitforum.org/showthread.php...-not-elevation
Just add a RP, lock the outlet to it and make a parameter.Dan
I am encountering an annoyance with my walls with integral wall bases.
I created a wall type that includes a sweep such that in all elevations...November 13, 2015, 02:42 PM -
Is there a way to quickly align two objects so that they become parallel to each other?
Let's say that I have two walls 10' apart from each other....May 4, 2011, 03:46 PM -
Im having trouble making a custom wall. I want a wall of a given height to have 4' of cobble stone with a flat stone ledge then the rest of the wall would...February 2, 2013, 05:33 PM
Is there a way to tie in (for example) a outlet to a wall so that whenever that wall moves (gets updated) the outlet moves with it.September 12, 2011, 02:35 PM
Hi friends,
I am attempting to create a wall hosted family that places at the wall core centerline. I seem to be able to select and lock...December 31, 2020, 11:59 PM
