For instance, i am making bathrooms wall, half of the wall dark tiles another bright. see Imbalanced example :ka:
How to split wall surface
Open the wall in elevation, use the split face tool (Modify tab, geometry panel).
Draw a line from edge to edge where you want the new material to be.
Then use the paint tool to apply the new material.
Or you could build a compound basic wall with 2 different materials.
Select the wall, edit type, duplicate it and name it another wall.
Then edit the wall, open the preview pane and set view to section.
Hit the split region button. In the preview section select the wall layer you want to split. Then assign it a funchtion and new material.Dan
Okay, enough with all the cool new workarounds already! Yet another POTM nomination. :laugh:
Seriously, very nice tip. I never would have thought to just draw another wall and join them. One question, why is it more stable than a compound wall? Granted, creating a compound all is way more work, but I was just wondering before I started joining walls all over the place for my restrooms. :laugh:Dan
Its more stable than Split Face. Compunt wall only works if its complete sections with different colors. If its varying (in elevation) then using those solutions doesnt work. We will sometimes do accents that arent stripes, or arent straight. That workflow works for all cases.(Okay, most of them)
One of the reasons we don't use Split Face much is that is doesn't know when to quit.
Say you've got a long corridor wall with several offices on one side.
If you use Split Face on the office side, you need to draw your own Split lines where the intersecting walls meet the corridor wall. If you don't, either the Face isn't complete, or your Painted Material leaks into the adjoining rooms. Which makes it difficult to use in an Interior Elevation. You may not notice that the Ceramic Tile in the Men's Room is also now in the HR office.
If Split Face would recognize intersecting walls, we'd use it all the time.Attached FilesDave Plumb
BWBR Architects; St Paul, MN
Or you could use a Stacked Wall; with individual walls each having the different materials on them.
Has advantages--more "solid" and won't get messed up by editing like split-faces do.
Disadvantages--a bit more complex because of it containing separate wall types, wall joins can sometimes be a bit tricky, etc.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Hello, I want to create a butt joint of two walls, but the problem is with the wrap of thicker wall.
It doesn't wrap at the connection. I tried...April 16, 2020, 11:48 AM -
I have a wall hosted casework family. We have a furred out wall and I am trying to get it to host to the interior surface of the wall rather than the...August 7, 2017, 03:36 PM
How can I clean up this wall condition. I wish the horizontal interior stud (single wall type) to come across to the window. The vertical wall is a wall...March 27, 2019, 07:57 PM
Hello,
Hoping somebody can help, how do I tell Revit the depth it should wrap at inserts, see picture below, it seems to wrap to the wall...March 17, 2017, 06:09 AM
