Baluster top and bottom cut angles
    I used the "Baluster" family template to create a baluster for my stair way. The top and bottom of each baluster needs to be cut parallel to the handrail. According to this AUGI thread, that's what the "Top Cut Angle" and "Bottom Cut Angle" paramters are supposed to enable.
    I drew my baluster and locked the top and bottom to the ref lines that are tied to these parameters. But my balusters are still coming in with horizontal tops and bottoms.
    Hmmmm. Just before I submitted this, I realized that these are NOT reference LINES. They're reference PLANES. I thought that if it's contro11ed by an angle paramter, you were supposed to use ref lines not planes.
Name:	Baluster Angles.png
    EDIT1: I forgot to include the referenced AUGI link. http://forums.augi.com/showthread.ph...-top-cut-angle
    EDIT2: I edited my baluster family and placed reference LINES, locked them to start at the intersection of the center lines and tied them to the angle parameters. Then I locked the top and bottom of the baluster to the ref lines. When I brought it into my project again, they STILL had horizontal tops/bottoms.
    Don Ireland
    Here's a screenshot of what the baluster looks like in my project. I'm also attaching a copy of my baluster family.
    I'm starting to wonder if someone's messing with me -- where's the camera? :hide:
Name:	Baluster Angles2.png
    Don Ireland
      Your baluster doesn't appear to be unique or different from the stock square baluster. Why not just use that? Have you compared it with your work? The angled reference planes in that template and baluster families are "special" because the "factory" put them there and Revit must be doing something internally to interpret the angle properly when it changes for stair or ramp rise/run.
        I have 2 OOTB balusters: square and round. My baluster is 1x2 and the square one only allows one dimension.
        Don Ireland
          I opened your baluster family, locked the profile to the line. Worked fine.
            I have to guess that you're talking about Align the sloped line in the extrusion with the top cut reference line/plane and then lock it. I did that and it didn't work for me.
            Don Ireland
              Here is the family after I edited it.
                This is getting really strange then. I tried it with your baluster and it still doesn't work. In the attached project file, I have nothing except the stairs/handrail shown in this screenshot. As you can see from the screenshot, I've still got horizontal tops and bottoms on the balusters.
Name:	Baluster Angles3.png
                Don Ireland
                  Looks like they are offset from the railing, if so there is nothing to cut off the ends. Cut a section or look at the stair from the end to see how they are lined up.
                    Yes. They're offset -- that's how they are in real life. In real life, they're exactly as I've shown in the screenshot except for the fact that the top and bottom angles are parallel with the stringer. They're nailed to the sides of the stair stringers opposite the treads rails -- and there is a "Handrail" sitting atop the upper rail. That's why the profile looks as it does.
                    I had hoped that they'd still pull the angle from the handrail.
                    I manually calculated what the angle should be (the stair slope should remain the same throughout every instance of this stair type). I then edited the extrusion in my baluster family so that it wasn't locked to a reference line -- it was just drawn at the angle that I need (basically eliminating it's parametric ability). When I attempted to use it with my handrail, all I got was "Can not create baluster". Of course it doesn't tell me WHY it can't create the baluster. It flexes fine when in family editor.
                    So how would you recomend modeling this handrail?
                    EDIT1: I've since created ref lines locked to the desired angle and then locked the top and bottom of the baluster to the ref lines and it still throws the error about can't create baluster.
                    EDIT 2: Corrected a mis-statement (see the strikethrough).
                    Don Ireland
