What Revit Wants: Using Shared Parameters to access data from built-in Family paramet
    Absolutely awesome workaround from Dave Light! He shows how to use an instance Shared Parameter to pass Keynote value via a Family formula to allow the tagging of Window Mark and Keynote in the same tag. Read the whole post here.
    On a wider level, this method shows that you can formulaically reference System parameters (built in family parameters) and pass their value to a Shared Parameter to allowing tagging.
    Author of What Revit Wants
