When you hover the mouse over a tool in 2012 the tool tip appears and in the bottom right it says "Video is loading..." and then expands out and says "To view the video get flash."
In 2011 on the same computer it works as expected and the video appears after a moment in the tool tip window. So flash IS installed and working properly.
In C:\Program Files\Autodesk\Revit Architecture 2012\Program\videos there are a bunch of .swf files that all start with GUID-.... with a long string name. They seem to be the tool tip videos.
Are the videos working for anyone else? I only noticed it because I was joining roofs yesterday and waited for the video so I could remember what edge to pick first. I don't join roofs very often.
Solved! Revit relies on Internet Explorer Active X Flash plug-in for showing the Tool Tip videos.
