:banghead: :banghead:
It's late and I can't figure this out! I need help.
The stone column attached works perfect except for one little issue. I've circled it in the front elevation view in the attached family.
I need the cast cap to have an overhang over the stone column. The default is 4", but it's parametric so I can adjust it. The problem is with the top cap location, by the angled part of the column. I can't get that to be parametric or to lock. When I change the height of the column, it does what it wants. Thanks in advance for checking this out.
