To my surprise, the 3d snapping in a curtain panel pattern based family works poorly. As a matter of fact, you barely can snap to points. I'm not sure how something like this could be broken. But if it is, we are in deep trouble since we can downgrade to 2011.
3d snapping gone bad in 2012
Originally posted by Andrew P View PostTo my surprise, the 3d snapping in a curtain panel pattern based family works poorly. As a matter of fact, you barely can snap to points. I'm not sure how something like this could be broken. But if it is, we are in deep trouble since we can downgrade to 2011.I'm retired, if you don't like it, go around!
When working in the Conceptual massing and Curtain panel pattern based environment, I usually could not have the type of Reference Points that I like....November 21, 2014, 02:54 AM
Attached image shows an example where pattern based curtain panels are "orthogonal" to the mass face. I would like to prevent the panels/profiles...March 2, 2018, 05:46 AM
I am trying to create what I think should be a fairly simple pattern based family to apply to a divided surface
See Image below
...November 6, 2011, 09:56 PM -
Hello everyone,
When i try to create a horizontal profile via 'create form' in Curtain Wall Panel Pattern Based Family, my newly created...-
January 25, 2021, 11:33 AM -
I think i'm missing something simple here, but I can't seem to keep my vertical shading fins oriented the right direction, they seem to have a mind of...May 5, 2015, 11:10 PM
