Can't place any room names
    Hi, I'm trying to place room names in my project but it doesn't show any blue room delimitation like it does regularly. It's weird because I can see all other rooms around that one and they are correct. And in an other project, when I put some new rooms, it only shows a small rectangle for rooms, it does not detect rooms borders. Any help would be very appreciate.
    In both cases, it's most likely the room-bounding issue. Check if the elements that surround the room are actually set to 'Room Bounding' and there are no 'gaps'. Also check bottom and top for any 'leakages'.
