Hi All,
Questions from the factory - Do you use the OOTB content for beams/columns? If not, how do you modify or create your beam/column families? Do you ever include additional content in your families, this could be additional profiles or arbitrary geometry?
What about non-uniform families such as castellated beams, open web joists, etc., OOTB or custom?
In communicating with external analysis and design software what is you process for verifying materials and section properties?
Thanks,
Erik Snell
RST User Experience Designer
Thanks,
Erik Snell
