Phases exports to DWG
    Can you control the layer an object is exported to with the phase it is on? It seems that the older versions of Revit were able to specify this on the layer export filter. Does revit 2011 have this or is it somewhere else?
    You can assign a layer for "Demo" and "Existing" from the Export Layers and Properties... Will that do?
      Why does the ISO13567 show the demo extg & new? And not my custom file? I've noticed that the ISO13567.txt sits in the programData while my custom export filter sits in program files. Additional the ISO13567.txt file when opened shows the lists of layers and properties etc and seems editable. The export filter files in program files doesn't.
      Is there a way of creating Demo, extg and new into my existing (somewhat tediously long custom made export filter) OR.... Does this mean I need to re-create my custom filter with file ISO13567?
      thx for the reply... this is painful.....
        Ok, I got it. I found the actual location of my filter export file, which wasn't where I stated as above. When I opened it, it was editable as per the ISO13567. I copied paste demolished txt with extensions from the ISO12567, which I can then edit my......lovely.
        ....... my bleating & whining was for nothing.... again......actually that would make a good signature.....
