KPI for a BIM Modeler
    Hello
    Good Day everyone.
    May I ask a question about KPIs of a modeler.
    What are the key factors that measure the performance of a BIM modeler ?
    How to define the KPIs for a modeler ? Let's debate
    Thanks !
    Are you talking about model authoring applications or model authors?
      If it's a modeling author, which I believe is what the OP is asking about, for sure it would have to be:
      - Ability to work directly in 3D/Plan/Section/Schedule at the same time, to show competency in interoperability
      - Ability to "program" information into an element for the purposes of documentation
      More will come to mind... is this what you are talking about?
        Sorry all, I was so busy that I forgot to check back this thread.
        Yes, I am asking about Model Author
        Thank you all
          Model correctly - to the correct level of detail
          Input the correct data - to the correct level of definition
          Models to the correct standards - in relation to object classification and following internal & external standards
          Doesn't do anything careless - such as import & explode CAD files
          Depending upon position in the project team, the ability to understand and create parametric data and create/edit families is also desirable.
          Mostly for me, the most important thing is someone that understands the rules and follows them. That's more important and efficient than someone who can model something amazing, but doesn't follow naming procedures.
          "I WANT SOUP! This fork is useless! I'm going to use my spoon for everything."
            Thanks Cyus
            • BIM and the UK Government
              Hello
              I know I am opening up an 'old chestnut' but I was searching for omniclass and bimnewbie asked the very question I was searching for....
              May 26, 2013, 10:01 AM
            • Calling on all BIM managers for advice
              Hello,
              I have created this thread to simply ask for advice from people who are already in the BIM industry on a number of things. Just to...
              January 20, 2013, 12:10 AM
            • BIM world
              hello, I apologize in advance for the inconvenience,
              I introduce myself, I Facchetti David, graduated in architecture from Milan Polytechnic, Italy....
              November 4, 2011, 02:52 PM
            • trouble with BIM
              hi guys!
              I write here, to make known that I came across an article the other day on web that talks about BIM and its infinite possibilities...
              October 24, 2011, 09:58 AM
            • From Revit modeler to BIM Manager
              Hi there people, got a question for all the BIM managers and Revit Modelers out there.
              The situation:
              I have been doing Revit modeling...
              August 30, 2016, 09:35 AM
