Stringers - Curved Stair.
    Is there any way to model a HSS stringer on a radiused stair? :banghead::banghead::banghead::banghead::banghead: :banghead:
    -Alex Cunningham
    You could switch stringer to none and use a profile of a HSS and load it in as a railing. I used the OOTB RHS profile as example.
    Mark Balsom
      Interesting.... I will tinker with this today.
      To get the job done. I just modeled them in place, picking the stairs geometry for my sweep blend path. Its working but I cant tage them like other framing members. As of now its enough to get them in for clash.
      Thanks. I will report back.
      -Alex Cunningham
        Alex, if you want to know more about freaky Revit stairs, you should really buy Mastering Revit 2011. The stairs section alone is worth the whole book... And you can download the examples from their site to play with.
