I've opened an old project with many good mental ray custom materials. I want to copy those out to my newly created custom library. You are suppossed to be able to drag and drop. But I can't seem to figure out how to do it. Any ideas.
Custom Material Library in 2012
From the materials palette, choose the material you want to transfer to your custom library. On the Appearance tab, choose 'By Property Set' for Properties. You'll be prompted to create new property set or select existing property set. Choose the option to create new property set. You'll now have a new property set with the name of the material and it will be listed in the property sets on the Appearance Property Sets tab. Now you can drag and drop that property set to your custom library.
I don't think they could have made this more unintuitive if they tried
Originally posted by muttlieb View PostOn the Appearance tab, choose 'By Property Set' for Properties. You'll be prompted to create new property set or select existing property set. Choose the option to create new property set.Jeff Hanson
Sr. Subject Matter Expert
The title says it all, I think. When I try to alter a material via Settings > Materials, at first hand the tab Materials comes up. Nothing wrong so...July 14, 2011, 07:05 AM
In materials browser, i have often wondered how to creat a new asset that has the correct 'properties present'. Like bump map. Is there a way i can instead...June 29, 2017, 03:29 PM
Hi, I'm trying to create a Custom Material Library at work that contains company standard materials, which can then be shared and accessed by my colleagues...March 17, 2016, 03:00 PM
When creating custom textures, are people creating all three sizes (256Px, 512Px & 1024Px)? Or just using one, and if so, which one? I assume if I...
Channel: Rendering and Gallery
May 21, 2011, 02:38 AM -
I'm looking for some good suggestions for training/tutorials on using the materials and asset libraries in Revit 2014. I do not have time to learn other...March 27, 2014, 05:40 PM
