Revit OpEd: Revit Journal Folder and Saving Files on Network Drives
    Revitform.org member "Cellophane" dropped this reminder/tip recently.
    When you save project files that DO NOT use worksets and family files on a network folder Revit stores a copy of the files in your user Journal folder. Since release 2012 Revit has been using this location for the Journal folder and files:
    C:\Users\\AppData\Local\Autodesk\Revit\Autodesk Revit "version"
    While chatting with support they gave him this explanation:
    • "This happens when saving directly to a network location as a data security function, i.e. if the network save fails, the data can be recovered from the local journals folder. If you save locally you will not populate the folder. The reason behind it is saving non-worksharing files to a network introduces a greater possible of failure, so dropping a copy in the journal folder is a way of recovering them."
    If you don't keep an eye on this you'll end up with quite a lot of files there. If other people use your computer and Revit then they've probably been "stealing" some disk space from your pc too. As tedious as it might seem to have to clean this out from time to time, the feature came in really handy recently when I managed to kill a few families that I thought I no longer needed. The next day a change came along and I needed them back. No, I didn't archive them for some reason...still not sure why. Regardless, the copies in the Journal folder sure came in handy though! I'm glad I didn't clean them out the day before.
