Hy I'm new in this forum. but I have a problem. I installed Revit 2012 but went I stared something has wrong with the conman Wall. then I began to uninstall but Something has wrong Again. The uninstall has stopped. an Now when I try to installed again they say it's all ready Installed. help me pleases.
Installation Problem whit Revit 2012
Hi Jmpimen, and welcome to the forum
You should try this solution from Autodesk, and then try installing again after a clean uninstall.Klaus Munkholm
Are you sure you have completed the steps listed in Step #5 of the above listed link
Code:Open the system registry (Windows Start menu > Run > Regedit). Locate and delete the following registry keys as appropriate. Windows XP/Windows Vista/Windows 7: 32 bit • HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit Architecture 2012 • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\Autodesk Revit Architecture 2012 • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\RAC 2012 Windows XP/Windows Vista/Windows 7: 64 bit • HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit Architecture 2012 • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\RAC 2012 • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\Autodesk Revit Architecture 2012 Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com. Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in the Microsoft Knowledge Base and in the related solution, TS66513. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
-Alex Cunningham
Revit Already Installed
I had the same problem, but as well as taking out the entries as suggested elsewhere from the registry, i also removed the product ID and names from thefollowing:
HKEY_CLASSES_ROOT\Installer\Products\
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Installer\UserData\S-1-5-18\Products\
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\
after i ran the setup again, it didn't appear as installed, and everything seemed to install ok afterwards.
hope this helps if you havent already solved it.
Hi, i installed revit architecture 2012 before but for some problem i faced like error of programmes when opening, i unistalled it and reinstallled it...November 3, 2011, 10:29 AM
I had created a new deployment for RAC 2012 . The deployed image is created successfully but when I m going install it ie Rollback. It shows a below error...February 24, 2012, 11:01 AM
Beginning January 1, 2012, Autodesk will have formally ceased support of the Microsoft Windows Vista Operating System for all new (and upgraded versions)...
Channel: Blog Feeds
February 2, 2012, 06:45 PM -
I'm having a problem re-installing Revit 2012. I recent replaced my over flowing SSD and as such had to do a complete re-install, including other autodesk...August 10, 2011, 02:19 AM
We got a new machine with windows 8. I am about to install Revit Structure suite 2012 but thought I would see if it is supported on windows...-
Channel: Hardware and Infrastructure
February 18, 2013, 09:36 PM -
