Wall sweep basboard goes to door opening, rather than stopping at door frame. It is usually fine since it is relatively easy to move the blue grip dot back to door frame although it is quite annoying.
When one side of door frame is right up against, it gets tricky. Since there is leftover wall, just the door frame width, there will be baseboard inside door frame. I can't get rid of this short baseboard.
The best solution would be to find an automatic way to have door frame automatically cut wall sweep baseboard. Is it possible?
Thank you.
Thank you.
