How to show spot elevation dimension on the ramp? its kinda impossible now, but maybe somebody know it? i know its "bended" and its impossible to show, but middle point will be decreasing constantly, and i need to show it. How?
Ramp spot elevation
What kind of view are you in? I know that it's not possible to randomly place SE's on a continuous surface in Section or Elevation View. Only possible in Plan View.
If you're in 2012, you might want to try to annotate in 3D. You can set this up using the Scope Box and Orient to View so that it looks like a section. Maybe then you can place these SE's (but I haven't tried it yet).Martijn de Riet
Then it shouldn't be a problem. Can you post (part of) the project?Martijn de Riet
Ok, the only thing I can think of is one of these solutions:
1. Create a section across the axis you want to annotate. Go to the section view, draw a refplane aligned to the top of the ramp and annotate the refplane.
2. Similar as above, but after creating the alligned refplane create two more refplanes on each point you want to annotate: one vertical and one horizontal (so you get a crosshair). name the horizontal refplane. go to the plan view and place the attached family on the intersection point of all three refplanes. Select as placement workplane the named horizontal plane. Now you can annotate this. Watch out though: this is simply a very small 2d circle created as a Generic Model. You might have to zoom in to see them.
I'm guessing this problem has something to do with the curved surface of the ramp, so the only way to make it easier is to recreate the ramp.Attached FilesMartijn de Riet
I know, you'll have to do a manual alignment "on sight". All else fails I'm afraid...Martijn de Riet
Trying to do something here and I'm not sure if it's possible. Can you somehow put an elevation marker into an elevation view? For example, if you were...December 2, 2011, 02:04 PM
My job this week is to build a site for a large project. There's a million workarounds, and I suspect sketchup is among my best options (side note: I'm...November 4, 2014, 10:40 PM
I just stumbled upon this. Like always, I'm sure it's well known, but I didn't know it. So, I figured I'd share.
So, I've noticed that...-
Channel: Tutorials, Tips & Tricks
July 27, 2012, 06:48 PM -
Okay so I have an elevation view in which you can see all of my topography (trees, hills, and overall scenery) in the behind my house. I have...January 30, 2014, 04:58 PM
Hi all,
First post...so please be nice.
I have created a family (a fire exit sign) with some symbolic linework to show what...December 21, 2015, 09:29 AM
