I have an Architectural model that contains several level datums that there are no floor plans associated to. These datums show up in section and elevation views and I'm having to Hide in View/Elements to get rid of them. Is there a way to purge or delete unused level datums?
Julien
P. DAC
Originally posted by Scott D Davis View Postyou can go to a view and delete them. Problem is that something MAY be hosted on them even though there is no plan associated with them. Deleting the Level would also delete thse hosted objects. Revit will warn you upon deletion that you are removing other objects, so you could try it....I'm retired, if you don't like it, go around!
You could create a (Shared) Parameter for visibility and use filters in your View Templates to only show the ones you want.Martijn de Riet
Originally posted by mdradvies View PostYou could create a (Shared) Parameter for visibility and use filters in your View Templates to only show the ones you want.I'm retired, if you don't like it, go around!
I am sure you have used Filters, but you have forgotten.
I don't think you need a "shared" parameter. Why? Create a new parameter in the project by Manage > Project parameters > add > , name it, for example, "Comments" (instance, text), applies to: Levels (in this example). Done. Then go to your project, select all the elements of that category that you don't want to see, and from the properties window, enter something in the "Comments" parameter, such as "don't need". Then go to View > Filters > Add button > name the new filter, such as "don't need stuff"; on the list of categories, apply to: Levels (in this case). On the right pane, from Filter by, select your "Comments" parameter. Equals: "don't need". Close the Filter dialog. Now, go to VG > Filters, Add > "don't need stuff" > Visibility = OFF. Close VG. All the unnecessary stuff is off. Later on, you can add this filter to your View templates, by using the "VG Overrides Filter > Edit..." button of the View Template Settings dialog box, and then apply the updated view templates to your views.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Alfredo Medina View PostI am sure you have used Filters, but you have forgotten.
I don't think you need a "shared" parameter.), so he'll need to set this up every project. Having it shared means that you can repick it every time without having to remember on a projectbase what you called it the last time.
Just my 2ct.Martijn de Riet
Originally posted by mdradvies View PostOk, you're right. Strictly speaking you don't need it to be shared. BUT: I would recommend it to be, just to be able to re-use it in different projects. Unless I'm mistaking, Dave hasn't come around to creating a Template yet in which this could very easily be incorporated (yes, we will keep bugging you about this), so he'll need to set this up every project. Having it shared means that you can repick it every time without having to remember on a projectbase what you called it the last time.
Just my 2ct.I'm retired, if you don't like it, go around!
I have a model I saved out from a larger project as a group. The group has five levels, Level 1, LEVEL 1, LEVEL 2, LEVEL 3, AND LEVEL 4. I can't seem...August 22, 2016, 10:55 PM
Hi Gang,
I havn't come across this issue before. Very interesting.
One of our modelers wants to delete a level from a model, it...January 11, 2012, 05:26 AM -
Is there anyway to query a level and find out if it is hosting anything.?
I want to know so that I can go thru the old levels that are...January 23, 2013, 02:17 PM -
I'm banging my head against the wall here :banghead: I'm doing some long needed tidying up in my project template and I have several redundant level types...October 15, 2013, 06:23 AM
I have been telling people for years that Revit needs at least one level to function. As proof, if you only have one level you'll find that Revit won't...
Channel: Blog Feeds
December 1, 2015, 05:45 AM -
