How to connect more rooms so it will show bigger area even though they are closed. In my case i want to join red marked rooms into above one.
Room boundaries
Hi!
I am having an issue with defining rooms that I cannot seem to get around. I need to create a room called "Master Bathroom"....February 9, 2015, 05:25 PM -
I don't normally deal with modeling floors, ceilings, or roofs but am doing some work for a Contractor creating areas for stucco soffits so he can tell...August 16, 2017, 09:16 PM
Hi, I'm trying to place room names in my project but it doesn't show any blue room delimitation like it does regularly. It's weird because I can see all...June 17, 2013, 11:57 AM
Is there a setting to adjust the room separator tolerance?
When room separator lines (and room bounding walls for that matter) get very...March 11, 2014, 02:40 AM -
I'm having a very frustrating problem, and can't for the life of me figure out what happened. Hoping someone else has had, and solved, a similar issue....May 24, 2011, 07:52 PM
